Comixbooks
- Jun 7, 2008
GeForce GRD 616.56 Feedback Thread (Released 8/26/26)
Our new GeForce Game Ready Driver optimizes your system for STAR WARS Zero Company™, Resonance: A Plague Tale Legacy, and Hell Let Loose: Vietnam, three new DLSS games.
Download the new driver through NVIDIA App , or from GeForce.com . Click below to learn more:
https://www.nvidia.com/en-us/geforce/news/star-wars-zero-company-geforce-game-ready-driver
Fixed Gaming Bugs:
Troubleshooting and providing driver feedback:
Fixed Gaming Bugs:
- DOOM: The Dark Ages & Indiana Jones and the Great Circle: Frame rate may exceed VSYNC when DLSS Frame Generation 3x or higher is used [6061475]
- Outer Worlds: Texture flicker may be observed while playing Outer Worlds after updating to R595 and R610 drivers [6238668]
- Asus Armory Crate: GameVisual color profiles are not getting applied when using R590 drivers [5860581]
- Chief Architect: 610.47 driver crash on Geforce RTX 4000 series cards [6226227]
- Claude Desktop: Driver incorrectly detects application as a 3D app [6468260]
- Resolves issue that some instances can cause a driver crash with 32-bit DirectX 12 apps [5725350]
- Tycho Tracker: Unable to create individual OpenCL buffers greater than 2GB [6538978]
- “Prefer Maximum Performance” Power Management Mode may not be applied correctly [6007998]
- NVIDIA Display Driver Feedback Form - Submit driver bug reports directly to NVIDIA
- How to provide valuable feedback to NVIDIA
- How to reach out to NVIDIA Customer Care for technical support
- NVIDIA App driver installation failed. How do I manually clean install the NVIDIA driver for my graphics card?
- Collecting NVIDIA App logs
- How to share feedback for low FPS/stutter/performance issues using GPUView trace logs
- How to save a Windows crash dump file after an application/game has crashed or is unresponsive.
- Configure Microsoft Windows to collect a complete memory dump file after a BSOD/bugcheck system reboot
- Collecting logs for display issues (flicker/blank screen/missing display modes)
- Enabling NVIDIA Debug Mode to disable GPU overclocking
- How to use Microsoft's WinDbg to troubleshoot application / system crashes
- How to capture D3D debug layer logs to detect application or runtime bugs (eg. to check if artifacts/flickering/corruption in specific games are due to an application or driver bug)
- How to delete NVIDIA Shader Cache files
- Download 3rd party utility Display Driver Uninstaller (DDU)
