Nvidia Control Panel leaving after 20 years
Comixbooks
https://videocardz.com/newz/nvidia-...lly-retiring-after-20-years-for-geforce-users
Hoping the new Control App is changeable on the Fly or at least give the Nvidia App a white Ui for readability.
As long as all the features and toggles are now in the new app, I'm fine with it. The old CP is quick and familiar, but mainly just because I've been using it for 20 years.
Something is off with either the Colors or Drivers so I slid Digital Vibrance down to 40 on both monitors. Usually I never mess with that slider at all could be early adaption woes.
Looks like the new driver is the the one that doesn't install the control panel. At least after using DDU.
I found everything I typically set without too much effort. Set my TV to the right resolution, 12-bit Color, G-Sync, Low latency on, Cap FPS to 118, Lock Vsync, Unlimited Shader Cache, and that's that.
EDIT: I'm not seeing a way to remove the Nvidia tray icon since that was tied to the old control panel.
Per the G3D forums, you can add this to the registry to purge it:
Windows Registry Editor Version 5.00 [HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\nvlddmkm\NVTray] "ShowlnSedona"=dword:00000000 "StartOnLogin"=dword:00000000
It's not just the filters in use that cause performance loss FYI - it's just having them on/enabled to even be used IIRC - just FYI
This was the 'bug' from a little back that people claimed the Nvidia app itself caused performance loss - the filters were just enabled/on by default - now they're off/disabled by default - again IIRC
