nvidia cards and 16x af???
Xenozx
Hi i have a BFG 6800 Ultra. i currently am running drivers 61.77. when i go into the drivers i dont see anything there but
up to 8xs AA
up to 8x AF?
how do you enable 16x AF on the new nvidia cards, i keep seeing a lot of reviews showing them running 16x but i cant find it any idea's?
its also to my understanding that you must be on performance setting to allow tri/bri filtering enhancements correct?>
Use the beta drivers like 61.71/72/62.20.
And no, you have to be on HIGH Performence to enable all the opts.
i was looking into puting the beta drivers on but they arnt in an easy executable file. how do you put them on your machine?
ok i figured it out, looks like you just unzip everything and choose update driver and make sure it scans the unzipped folder and it updated perfectly fine, kool thanks for your help guys/gals!
Only the 62.20s don't come with the setup files. The others do.
hmm...
i installed them and then realized i lost the overclocking option. I then proceeded to add that registry edit and it put it back to the image above any idea's?
um i did a search in my registry for coolbits and this is what i find...
if i remove that edit there will it fix the problem. also i see the words
TROJAN
DOWNLOADER
which dont look good either. will i hurt anything by removing these. i usually dont mess with the registry so if you guys can point me in the right direction.
TROJAN
DOWNLOADER
err suggest ya get adaware and run a system scan. Registry delete will only remove the link not the acutal program.
my norton keeps detecting those things and tell me they are not files or something and there for there is nothing to delete, and it tells my by giving me this warning it has blocked it from doing what its soppose to do. it also says something about access denied and could not repair/delete/quarenteen.
i would really like to get the reg nvidia drivers back and then ill just use powerstrip or something for overclocking.
ok went into control panel and removed drivers. i am reinstalling 62.20's now will let you know if it fixes the cool bit thing. gotta restart.
