Nvidia card on AMD Chipset
godsfshrmn
This is a silly question I believe. I have always paired an NVIDIA chipset with a NVIDIA gfx card because I thought that's how it had to be. My question is would an AMD chipset (790gx) work well with an NVIDIA gfx card (9800gtx for now)? Most of these have integrated ATI video chips as well. I guess that could just be disabled.
You'll be fine running nvidia cards, just no SLI.
And yes, go ahead and disable the onboard video :)
Ahh that sucks, no SLI. I did see you could crossfire the onboard w/ a PCI ATI card, but could only run DX 10 and not 10.1 (which I'm sure isn't much of a difference). Looks like my next card will be an ATI for the crossfire, assuming DX11 will work with the onboard.
I noticed a vast majority of boards on Newegg are AMD and very few are the Nforce chipsets. Have they gone downhill over the past few years? I used to know all about what was going on when I built my PC about 3 years ago but naturally everything has dramatically changed since then.
You're talking about hybrid crossfire (onboard+card). It can enhance the performance of slower cards but if you are going to go with a mid to high-end ATI card I don't think it will matter at all.
NForce and AMD chipsets have both had their share of reliability issues. Many of the best boards now use Intel chipsets, even more so since you can run either SLI OR Crossfire on an X58.
As said above the hybrid crossfire is only useful for very low end cards. If you are running any decent stand alone card you are already miles ahead of anything the hybrid crossfire could do for you.
True! like i have a on board ATI HD 3200 card and i had a X1950 PCI Express card and i did the hybrid SLI but i never really could tell the diffrence.
