MSI MS7345 Platinum MoBo
DirectX 11
Intel Quad Q6600 2.4 GHz
8GB PC6400 DDR2 RAM
NVidia GeForce 8600GT / Viewsonic VX2035 LCD Wide
Hi,
I also posted some of this message over on the Monitor Forums, because I simply do not know which is causing my problem. The GPU, or my Monitor.
December of 2007, I purchased a GeForce nVidia 8600GT PCI-E 513MB DDR2 128 BIT GPU.
In March 2007, I purchased a new Viewsonic Vx2035wm LCD 20" Widescreen Monitor.
Are there any signs I may see before either of these two things go out?
I noticed a changing of colors, starting with the boot up language on the screen that is ordinarily white, but once or twice tonight when booting up, the letters and numbers seem to be switching from white to a light pink. I also see color changes on the desktop, and even now, while I'm typing this out in Word, the blank white area on the page seems to be fading in and out.
I just re-installed Windows 7 Pro, and installed the most recent drivers for both these devices. Is there any way to pin point which of these two devices could be going out?
Are there any other tests on these devices to see what going on? I was going to upgrade my GPU when I upgrade my MSI P35 Platinum MoBo with a newer board with DDR3, more memory, and a faster Intel i5, or i7, I'm just not ready to do that right now, if this is the GPU. I think this Mobo had integrated graphics onboard, in case it is the GPU.
Thank you!
DirectX 11
8GB PC6400 DDR2 RAM
Hi,
Thank you!
