I running a velociRaptor and thinking of buying another for RAID 0. I have no experience with RAID 0 and wondered if any of you RAID 0 guys noticed a performance increase.
This is a huge grey area. RAID 0 can increase performance under certain conditions, like when you're reading loads of huge files. But for every day use, the only way to actually 'notice' a difference between a velociraptor and 2x velociraptors in RAID 0 is by running something like HDTach.
If it were me getting a second velociraptor, I'd use one for the main OS partition, and the second for the installed programs folder(s) and/or page file.
But even then, I'd argue that the $180+ you'd spend on a second velociraptor would be better spent on practically any other PC component. Also, there have been several new SSD annnouncements made recently, most of which will probably hit the market ~CES time. If you're just itching for faster HDD performance, I suggest hanging on to your money until late Jannuary. At that time, you should be able to get fast SSDs for RAID 0, or get a velociraptor for less money due to SSD competition.
Pagefile? Like his system is going to swap alot with 4GB RAM (which is standard now-adays). And with 15 euro for 2GB memory there's no real problem to expand if you're low on RAM.
RAID0 is great, and also increases IOps and processing small files; not just large file transfers as often stated on forums. But 1) you need a proper controller/driver and 2) you need to align your filesystem or you won't achieve maximum performance.
If you are to proceed, make sure your chipset supports RAID; don't use a PCI add-on controller. Setup the drives with maximum stripesize (often 128KiB) and test away with ATTO-256 et al.
