Well i have tried almost everything to get this run properly but i cant find a way to change memory amount on that . IT only uses 64mb atm but it says in doc that it can be changed up to 512mb turbo cache .I cant cahnge it in bios , it has some crapy Pheonix bios loaded it wont allow to change anything there.
I only got 4700 points in 3dmark01 , i should be getting at least 10k in there.
CPU Core Duo T2350
1gb DDR2 533'
160gb Samsung
Running Windows XP
Any help would be good.
CPU Core Duo T2350
1gb DDR2 533'
160gb Samsung
Running Windows XP
