nvidia 6800 65.73 driver /help
Ruhl
I downloaded this new driver. I still dont understand why it is not on the nVidia site. If anyone out there knows How to install it and can post it here it would be a big help,
thanks in advance
http://downloads.guru3d.com/download.php?det=854
You need to install the driver the old school way though, there's no setup.exe included. This means you need to update your drivers through your driver properties, if you don't undertstand this then don't even try it.
> System properties > Device Manager > Driver > Update
Please do uninstall your current ForceWare drivers properly.
Nods head in agreement... actually hehe ok just open your control panel, then system, then hardware properties...then choose your graphics card...then choose driver...then choose update driver....and thru the browser locate the unzipped files and go to that location and the driver.inf should appear and choose install. Whola... :)
