I have a 6600GT, with DVI out as well as VGA and Analog out. I have a VGA monitor hooked to the VGA, and a DVI to component coverter on the DVI port.
I want the DVI component out to run to my HDTV (which supports all major resolutions) however it appears the box I bought from newegg (http://www.newegg.com/Product/Product.asp?Item=N82E16814999903) only works with ATi cards. That detail wasn't on the listing when I bought the card, and I bought it several months ago, so there's no hope to return it.
I've gone through the gamut of nView Display Settings, particularly custom resolutions for 720p NTSC. And I'm sure everything is configured properly, but alas no picture.
So I assume the box is not nVidia compatible. Anyone have any insight?
