Nvidia - 1920x1080 over DVI
big_kel
I have an nvidia 6200 and want to run 1920x1080 over DVI to my dell 2407fpw but for some reason when I set the card to 1920x1080 it stretches to 1920x1200 and the monitor still sees it as 1920x1200. Anyone know how to fix it cos I can get the PS3 to work at 1920x1080 but not the PC.
Don't know why you would want to run that resolution to the monitor from your PC because it would result in non-1:1 pixel mapping and look like garbage.. but go into custom resolution and timings to set it up.
If he has the A04, it will do 1:1 for him.
I have (as an experiment) run my Dell 2407 at 1920x1080 from a R9200 without difficulty. Did it seperately using CCC and PowerStrip. Look for a setting to allow 1:1 mapping -- either on the monitor or under the control panel.
Well it still doesn't make sense why he wants 1920x1080. If he wants to play movies with a native 1080p resolution, they will playback on the monitor just fine with the black bars, and he'll get 1:1 pixel mapping anyhow. What I think he wants is 1920x1080 to take up the whole screen, which would not be 1:1 pixel mapping. Or else, why would he even ask the question? :confused:
