NVHardpage / Coolbits Problem
Hi,
I am having some difficulties with my 6600GT Leadtek TDH. My coolbits OC program is only reading my core speed of 300 when it should be 500 ? but the memory is showing the same (900) as it should! Why ?
http://www.guru3d.com/nvhardpage/ < ------ Version 2.1 (im using)
Also, what ive noticed is that nVidia is showing a lack of intelligence. This could be down to using the better video drivers but you go to the display properties ---> Settings ---> Geforce... (your card) it will show 4 settings for your 'Max AGP Rate'. However, the 'OS' AGP rate is only showing 2x on my 6600GT and this was showing the same with my other Geforce cards, WHY IS THIS ???? All the others show 8x as being an 8x AGP card.
The video driver version im using is 66.93
These could be 'n00bie' questions to some, but i need answers, lol.
An off-the-topic-question. Whilst trying to enter 'My Computer' for some reason it will go to search instead of actually opening it up fully, why ? when i right click the default is 'search' rather then open :s
Thx for any help........
Im not sure if this helps but are you looking at 3D core and not 2D in the overclocking tab? ;) :confused:
