Well I put my new NV5 Silencer with Arctic Silver hoping for higher clock and lower temps.
I am running a PNY 6800 GT, bios flashed to 1.4 volts, running at 370/1050(was waiting for higher till Silencer was installed).
Temps with stock 6800 GT heatsink were 51c at idle, would go up to 75c or so under load.
I put on the NV5 Silencer with Arctic Silver, made sure the fan was running.
As soon as I booted into windows my idle temp was 52c, this is before any gaming or anything. I loaded up the temp log in RivaTuner, and playing some Doom 3 for about 15 minutes to get the temps up.
Looks like the maximum temp now is 79c, weird thing is though, the graph in RivaTuner under the stock heatsink was pretty linear in its increase and decrease, now the graph is extremely jagged, like it jumps up and down a few C seemingly at random.
Its been about 20 minutes since I quit out of Doom 3 , and my idle temp is 55c now and it took a long time for it to go back to that, before it would drop 10c almost instantly apon quiting out of the game, now it is a slow proccess.
The only thing I can think is I didn't use the little black backplate that was originally on the 6800 GT but I dont think I need that.
Before I did this I scrubbed off the ram chips and GPU with alcohol, the GPU had a near mirror shine.
Now I know you might say "Not enough/too much thermal grease" thing is though because I didnt want to pull the card out of my computer, I was very careful with my grease, I put just enough, not too much, same amount as my cpu which is going strong and cool, I tightened the pins with a screw driver a lot for good solid contact.
I also put just a smidge of grease on the ram chips, not a whole lot compared to the cpu, but enough to ensure contact.
Also, I don't feel a steady stream of air coming out of my case from this thing, I just double checked and the fan is indeed blowing.
Any ideas? This isn't the end of the world but when you pay $40 for something you expect it too work, bleh
