stryder2720 said:I used AS5 only on the core then the regular paste on the memory....to take up for the gaps I had between the memory and the NV5.
Sure did/does.laserbeam said:Sounds logical. Did it perform?
LoneWolf said:I used the stock stuff and it worked just fine. It's not AS5 perhaps, but it's better than $2 Radio Shack. I don't think it'd make a difference of more than a degree or two if any difference at all. My GPU (6800NU) is 10C cooler than it was stock, more in some cases, and that's good enough for me.
aZn_plyR said:those renamed koss portapro's are on sale @ radioshack though!!! 19.99 hehe
Ke0 said:Radio shack sells thermal paste? *shutters*
um lol mine is sitting 55C idle stock @ 410/1100mhz and thats the OC the nvidia auto oc gotstryder2720 said:Sure did/does.
My GT is sitting at 415mhz core/ 1114mhz memory right now and idle @ 48-50c.
So did mine before I did.....Ballz2TheWallz said:um lol mine is sitting 55C idle stock @ 410/1100mhz and thats the OC the nvidia auto oc got, with those damned 71.84's that read hotter then they should
wtf is that a A64 cooler moded into a NV5!? god lol that must be alot quieter then the stock nvidia cooler which is easily twice as loud as the 4xLianli case fans A64hsf and nb fanstryder2720 said:So did mine before I did.....
THIS!!!!!!!!!!!!!!!!!!!!
mine is also on the 71.84s.
