NV40 with an Antec true 430??
RM_Bulldog
i think that this PSU is better than say a 480w generic additionally the NV40 is said to pull hard of the 12v rail and i looked at the max amps on the antec and thermaltake 480 PSU's
and there both 18A exactly what my antec 430 has, so wouldnt an antec 430 tru run a NV40 just fine??
I have a buddy who works at Nvidia... he says that they are recommending 500w power supplies... all there test rigs had antec 550's... supposidly the retail boards will only have one molex plug... but who knows...
...right.........:rolleyes:
Do you guys think that an Antec 380W power supply would be enough? All I've got is an A64, mobo, CD-ROM, and a single hard drive.
yeah i don't see why not. if you look a tthe graph in the link that system isn't even crossing 200watts with the 6800u even under heavy gaming I can't immagine it taking over 100watts more power
I would guess anything above 400w would suffice. That is, if you don't have 4 hard drives and three optical drives... :). As for me I'll have 1hd and 1 or 2 optical drives. Hopefully an Antec True 430w.
I have an Antec true 430 but for sure i will upgrade to antec or emermax550 just to be sure.I'll just buy it and be sure cause comps are expensive.
Dunno about you, but my TP430 puts out 20A.
The power problem is one issue to think about, the dedicate rails is another one. Dam I haven't looked but I think I'm tapped out.
4 HD + 5 fans + 1 GC + 1 CD, dosn't look good to me, but then again I won't be upgradeing, LOL.
Well according to the guys @ Tech Report, the GF6800 is sucking up about 206W under load. About 30W more than the 9800XT and 10W more than a 5950. My guess is a 430W PSU would be fine.
I've got 4 hard drives and two optical drives. :(
why don't you just get the card, try it, if it works, great. if it doesn't, get a new psu.
Is it possible that it could damage some components if it doesn't work?
not really, the computer just won't work, or will not work properly. In all likeliness if the PSU isn't up to it, the machine won't post.
people the card is not out yet. no one on this forum but kyle and brent can answer that since there the only ones who have one in hand.
I know but really i just wont take chance if it kills something way i see if i'm gonna spend over $1,000 in upgrading just buy better power supply and be sure ,but i'm sure it might work i just dont wanna take chance.
I recently installed an Antec True 330W on an older computer and used up all connectors. So I wrote Antec an e-mail saying they need more direct connectors on future power supplies.
Well Im not certain about silicon but I am certain that not providing enough juice to electronics does burn them out.
well im gonna have 1 harddrive 2 opticals and about 6 fans and i bet the 430 is just fine :) 10 more watts than a 5950 is all a 6800 uses so imnot scared :)
Recently just added a second HDD to my system, so I got
120 WD SE
80gig WD SE
Plextor 708A
TDk 16x10x40
Lazer LEDS
Multiple fans
9800pro
P4c @ 3.3
And so far my 430 hasn't hiccuped, so I don't forsee a problem. Though I would definently like to have a modular PSU and sleeving done right *my job is turning out pretty crappy* but I hear Antec is putting out a new models soon I heard.
Better quality powersupplies will just shut off if you go over the amperage limit on any of the rails.
So, if in the middle of gaming the whole computer just shuts off its a pretty safe bet that the powersupply is not adequate.
The truepower 430 is 66 bucks on newegg and the 550 is onyl 96 bucks...Why not just get the 550 and not worry about the PSU for the next few years...
MAny of the cheaper PSU's will fry and take out other components if put under too much strain. But my guess is that any 400+ watt name-brand PSU will be A-OK.
and I just bought a antec 380W truepower psu. i only have 1hdd, 1 optical drive, and 3 fans, im guessing i would need a new psu to run the 6800U am i right?
I would not be surprised if your TP380 ran it just fine.
Didn't Dell used to run Radeon 9700s with PSU's that were much less than 300w? And ATi recommended a 300w PSU? Just an example showing that recommendations aren't always a necessity.
I want someone to test the 6800U running on a Antec 380w TP and see if its alright
Yeah, but you don't want to run a powersupply for too long at its limit. Its always better to be a little bit over.
Powersupplies (the big caps in them) do not like to be stressed to 90+ percent of their capacity. It exponentially reduces the life of them. So it may work fine for a few months, and then one day you just hear the pop, see the blue gas (and the awful smell of burnt PCB/leaking cap fluid) Then you are heading to the computer store to buy a new one.
Brand name powersupplies usually give the full amperage at the specs written on it, you defnitely want to avoid generics.
480 is probably a worst-case scenario from Nvidia.
Think it through though, if you are overclocking a PrescHot (maybe 120 watts) with a couple of harddrives a couple CD drives, and quite a few case fans then by all means get the 480+ (you'd better get a 550 in that case)
If you are running an AMD Opteron HE (55 watts) or EE (30 watts) one harddrive, one DVD writer and the standard two case fans, then I'd almost say you could get by with a good brandname 350+
Wait a second here, that 206 watts is for the whole system, not just the video card. Not sure if you realized that or not, you might want to go back and edit your post to make that point clear for everyone else.
Hey that's good to know. Well at least 30W over a 9800XT and 10W over a 5950U isn't too bad. I really do think a good 350W could pull it off.
Here's my setup, what do you guys think:
P4 2.4 ghz @ 2.9 ghz (~60 watts)
4 x 7200 rpm HD's
3 optical drives (dvd, dvdrw, cdrw)
GF3 primary video
GF2 mx secondary video (coming out next time I open the case, don't need it anymore)
6 fans, incl. CPU fan
1 stick, 512 megs, RAM
My PSU is an older Enermax 421w unit with 20a on the +12v line. What worries me is that it puts out fairly warm air all the time, which makes me think it's somewhat near capacity. I've also lost 2 hard drives while using this PSU (wiring in house is ok).
I highly doubt it, but do you guys think I'm near maxing this thing out? Also, anyone want to guess whether or not I can swap the GF3 for a GF6800u and keep the current PSU? Thanks :)
You cannot really go by overall wattage, as its probably straining the 12 volt rail.
It might be divvied up like 120watts pulling on the 12 volt, 40 watts on the 5 volt and 40 watts on the 3.3volt. Although its 200 watts combined there, no 200 watt powersupply made today can power a machine with those specs.
The way that powersupplies are made today, at approximately 60 (on cheap power supplies) to 68 (on good powersupplies) power conversion, and leaving a good 10 percent leeway in a higher end system (P4's/AMD opterons and such)... Yeah, 480 watt is a reasonable "safe" powersupply.
Funny, considering every reviewer has gotten away with FAR less power. 3dgpu.com got it working fine in demo loops with a 200W in a SFF PC. Your friend might work in the janitorial department.
If the machine draws more amps than the powersupply can handle, most quality powersupplies will shut themselves down.
1x dvd rom
1x cd-burner
3x casefans
1x swiftech fan on heatsink
1x 7200 ide drive
2x scsi 15 and 10k drives
on some crapass 400w power supply, IFFFF I get it i'll upgrade.
I think if your going to spend 500 bucks on a video card you can dish out the extra 81 bucks for a true power 480 or 100 for a 550.
I think the strong rails giving on a higher wattage PSU are wha tthe 6800is looking for, ill bet a good quality 400 mabey even 350 woill still work...
But i dont knwo about the cheapass 350s
