Hi all.
I just switched from AMD R9 290x Crossfire to 2 980 TI SLI.
Here's my problem, after setting up the surround with 3 panels and reboot, the system revert back to extended desktop with 1 monitor being off.
I am following the port guide according to this link.
http://www.geforce.com/hardware/technology/surround/system-requirements
It seems that no matter what I do, the monitor that is on the 2nd card is not kicking back on until I reconfigure SLI after the reboot.
Any suggestion?
I have cleaned the system with DDU and is using the latest nvidia driver.
I have tried every possible combo of cable, 2 DP & 1 DVI, 3 DP port cables etc still no luck.
Have anyone have this issue or got a clue on how to fix it short of a fresh install and that still doesn't seem to guarantee a fix.
Thank you.
Any suggestion?
Thank you.
