freddiepm61
- Oct 19, 2004
Does the nv silencer actually work well. Though in reviews they state that it cools excellently, i have read on this site very often that it is often difficult to attach, and does not always come in full contact woth the core and ramsinks.
is it just luck of the draw?
can you return it if it doesn't work, or will you always have to do these modifications to it to make it work?
wil it work with sli, i.e will two of them fit?
as always thanks for your help
f
f
