I just wanted to say thanks to all the [H] members out there. I've been reading and posting aobut getting an NV Silencer 5 (rev.2) for my Gainward 6800GT for several months now. It showed up in the mail, purchased from bigfootcomputers.com (I'm in canada, hence the wait for the product to show up at a Canadian retialer) and I spent about an hour installing it. The difference in audible noise is absolutely indescribable, as everyone who owns a Gainward knows their dual 60mm stock fans are pretty decent at cooling, but they're noisy as hell. The silencer is completely inaudible over my other case fans (Vantec Stealths and the fan in my Neopower 480W), and the install went swimmingly. I could probably drop a handful of degrees more by using AS5 instead of the ceramique I used, but I was super paranoid about shorting out the card. I know AS5 wouldn't be a problem at all in this case unless I literally emptied the tube all over the card, but I wasn't in the mood to replace the card from a botched install, so I was just being careful and going completely non-conductive. Anyway, long story short, the install's a complete success. Lower idle & stock temps, insane reduction in noise, and one happy customer. Thanks guys, I appreciate the help.
Oh, also, I was so focused and excited (and lazy) during the install that I only managed to snap off one pic. I was focusing pretty hard so as not to botch the install, I'm sure you guys'll understand. Behold, my naked Gainward!
....Okay, so the batteries in my D70 just died, I'll post pics of the naked Gainward and the leftover parts, perhaps a ghetto side of the open case pic if i get a chance tomorrow. Thanks again guys!
EDIT: Recharged and feelin' fine. Also, I'd like to mention that my Gainward's stock cooling solution wasn't really set up perfectly. Thermal paste was applied properly, but the GPU block wasn't tightened down on one corner at all, and it was very loose on the opposite corner. The other two corners were tight as hell...odd eh?
