HotShotMedic
- Aug 3, 2006
Who here jumps into the control panel as soon as you install new drivers to change the texture filtering option to 'high quality' from its default of 'quality'? I've been doing this for years now but I'm not sure why as I usually can't tell the difference. I also set Negative LOD bias to 'clamp'. I usually own high end gpu's that can max the games of their generations so I don't see a performance hit using these options.
Thoughts?
Thoughts?
