Gilthanis
[H]ard|DCer of the Year - 2014
- Jan 29, 2006
With the latest subfield (#25) nearing completion, the algorithm moves into a new phase, where it is more efficient to not target the field discriminant. This required no change to the app, but due to WU timing issues, a small change was made to the WU generator (it is now breaking data up into finer pieces). This required a small change to the app interface. I also upgraded to the latest versions of the boinc and pari libraries. Some modifications were also made to the checkpointing and progress meter (finer resolution).
Why am I telling you all this? Because you will be getting a "new" bounded app. It has been thoroughly tested over the last several weeks, but please report anything out of the ordinary. Thanks!
http://numberfields.asu.edu/NumberFields/forum_thread.php?id=212#1123
I created an account called HardOCPtest so that anyone whom wanted to test or contribute anonymously could do so.
•to attach a computer to your account without using the BOINC Manager. To do so, install BOINC, create a file named account_numberfields.asu.edu_NumberFields.xml in the BOINC data directory, and set its contents to: <account>
<master_url>http://numberfields.asu.edu/NumberFields/</master_url>
<authenticator>21020_19611dc31727f3da5955a6641150c08c</authenticator>
</account>
