I'm not new at building systems but not as advanced as some of you folks. Here's what I have:
ECS K7S5A V.1
AMD T-Bird 750
GeForce DDR 32mg (1st ver)
256 PC133
1.3 GB HDD with bad sectors(20.5 went south)
no CDR or floppy (both went south)
case is shot
Basically what I have is garbage. I can put together a decent P4 2.8 for $500. Or I can salvage the MB and slap a XP 2400+ or 2600+ on it after bios flash and have a working PC sooner than building a P4. And do a new board later with some cpu upgrade room. New HD, CDRW, floppy, case and vid card are new parts in the build. By buddy's trying to get me to buy one of these:
http://www.microcenter.com/single_product_results.phtml?product_id=180730
I've always built my own boxes. Want it to stay that way. As I said before, I'm not as advanced as alot of you folks. Should I hold off for a P4 or can a better system be built than this Compaq above? Or trash the whole box above/start over or salvage the MB? I use my box for internet, Office 2000 stuff, a few games and will be using for video/photos later on. Most of the components for this potential P4 box are refurbs from NewEgg. Your thoughts please!
Thanks,
Brandon
ECS K7S5A V.1
AMD T-Bird 750
256 PC133
case is shot
Thanks,
Brandon
