nub oc'er looking for assistance
cugine
I have Q6600 G0 stepping, evga 680i NF68-A2 MB with 4 x 1gig gskill memory.
I oc'd my processor to 3.2 GHz left stock voltage to 1.408v and all seems well. I set my memory to synchronous and I did not change the voltage. I did change the clocks to 4-4-4-12. The machine is running great. Any recommendations as to what I can increase to improve performance?
Thanks,
cugine
my.php
my.php
my.php
Well, if you're stable, you can try to go higher on the FSB and vcore. Should be safe up to 1.5V on the vcore for 24/7 if you have good enough cooling.
Do I have to increase the vcore in order for me to be able to increase the FSB?
Right now my FSB is 1426 and my vcore is 1.408. What about increasing the bus speed? It is 356.5 MHz. I think it is being down-clocked.
Thanks,
cugine
