Nub here, would this system work for a SFF
dev1nsan
I'm going to attempt my first PC build in July when the Intel price drop, I'm just starting to do research into building my own PC and I really like the look of SFF especially the Lian Li v300, anyways I was wondering if this configuration would work in a SFF case.
heres a link to the components I will most likely purchase
http://computershopper.com/feature/build_your_own_budget_gaming_pc_1
basically consist of
graphics=8800 GTS
processor=intel duo core E-6600 (or maybe a higher one since price is going to drop)
mobo=Asus P5N32-E (this is probably where I'm gonna have to change if I want SFF right?)
cooler=Thermaltake Big Typhoon VX CL-PO310 (proably need to change this too)
ram=2 gb ddr2 800 (not sure what brand yet)
and sound card=Sound Blaster Audigy 4 SB0610
Your system looks great, but the motherboard you chose would not fit into the v300. Get the abit F-I90HD if you want to overclock or the asus P5B-VM if you don't overclock. I am not too sure if that heatsink would fit into the v300.
