nTune locks up my system..
cpush
Recently, and I have no idea why, nTune has decided to hardlock my system when I try opening it. It has worked fine for the last 2 months I've had my system. I started experimenting with overclock combinations and memory timings and wasn't too successful. I noticed nTune would lock up my system, so I set everything back to my previous set up and it still crashes my system, I have re-installed and no luck. Any info would be appreciated. thanks
vnf4 ultra
venice 3200 @ 2.6ghz (1.6 volts)
1gb geil pc4000 @ 260mhz (2.5 4 4 7)
ocz modstream 450
Might want to check the BIOS and make sure the settings are still at their default. You might also want to check your system for any virii/spyware/malware/etc. On the same lines, make sure none of your other installed software is killing the app, or trying to. Aside from that, I'm not too sure what could be causing it.
