Originally posted by oqvist
Was probably overclocking my fsb to high or ran to low voltage and got this message.
I don´t remember the exact filename but should I replace it or can windows XP self repair it? I was able to recover and boot again so...
Originally posted by nst6563
If windows boots and runs fine now then there is no need to worry about it.
You got that error probably because (like you said) you o/c'd too high. When your computer read from the file, the data got corrupt in memory, and the error handling in windows generated that error for you. I assume it went "normal" again once you backed down the speeds???
This has happened to me a few times. I can't seem to get past 185fsb with my 2.4b. I'm stable all the way up to 183, 184 is a little shaky, and 185 is a definate bomb (boots into windows, but crashes every couple minutes). I've tried relaxing ram timings (shouldn't be an issue with the sticks I have. Geil pc4000 running at cas 2, 3-3-7. I can run lower 2-2-3-5 if I wanted, but would rather have gauranteed stability), better case cooling, new thermal paste, etc... haven't gone extreme with water cooling though.
believe me...if windows stopped loading that file...windows wouldn't load period.
consider yourself lucky because many times an overclock too high will cause hdd corruption and then you're back to square one re-installing everything. Happened to me when I decided to try to boot at 198 fsb (even though my cpu is rated for 133, I soo wanted to hit 200...but I guess a 725Mhz fsb is close enough to 800 to make me happy.)
