oiiwj
- Nov 24, 2016
I have found i am unable to access directory on the drive. So i disconnected the drive (USB 3.0 cable of the dock station) and then i have found that the computer's USB 3.0 connector that was used to connect that drive is unable to recognize this drive and other USB 3.0 flash drive, but IS able to recognize USB 2.0 flash drive.
In device manager is no HW error. So i connected my problematic drive to USB 2.0 connector and it asks formating. Windows drive details shows 0 bytes. SMART is OK.
Windows 10 Drive manager displays the drive as ok, online, RAW.
I have found some commands that may help fix this:
I tried to start partition recovery test using Minitool Partition Wizard (it already worked once for different drive of mine that turned RAW), but it feels so slow and if i counted the speed right, it may take like 5 days. Then i launched Data recovery utility of the said app and it began searching and shows 113 hours remaining (5 days). Minitool support things that i do not need partition recovery, but data recovery: "Partition Recovery module is much more professional and useful when partitions get lost or disappear but your partition still exists and shows RAW which means there are some errors with the file system. And the Data Recovery module is designed to recover files from the logically damaged partition, formatted partition, and RAW partition as well as to recover files mistakenly deleted from internal or external hard drives. "
What do you think about this and what would you try?
C:\WINDOWS\system32>convert G: /fs:ntfs
Drive G: is already NTFS.
C:\WINDOWS\system32>CHKDSK G: /f
The type of the file system is NTFS.
The first NTFS boot sector is unreadable or corrupt.
Reading second NTFS boot sector instead.
Unable to determine volume version and state. CHKDSK aborted.
C:\WINDOWS\system32>diskpart
list disk
select disk X
list part
select part X
detail partition
Partition 2
Type : ebd0a0a2-b9e5-4433-87c0-68b6b72699c7
Hidden : No
Required: No
Attrib : 0000000000000000
Offset in Bytes: 135266304
Volume ### Ltr Label Fs Type Size Status Info
* Volume 4 G RAW Partition 14 TB Healthy
