nsgminer
Riccochet
[H] for Hours
Using nsgminer with my sig rig to mine FTC. Currently I'm only getting around 340 KH/s, and I feel it should be higher. The other problem is I have a ~20% invalid rate.
Current config:
nsgminer.exe --neoscrypt -g 1 -w 128 -I 18 --gpu-engine 1060 --gpu-memclock 1600
GPU loads up to 100% and stays around 80C, which is normal for this card.
Any way I can squeeze some extra out of it and reduce the invalid rate?
I don't know much about FTC but does it support multiple algorithms like other alt coins? Maybe there is one with similar performance but less bad invalids. You could try a different driver version too just to see if its something wonky going on.
As far as I know FTC only uses neoscrypt. I had to play with the settings a bit, but I think I have it dialed in. Getting ~400 KH/s now with about 8% invalid rate. I can live with that.
I might start ETH mining as well since it's my understanding that both can be mined at the same time.
Just doing this for shits and giggles during the day when I don't really pay for electric. Solar panels pretty much cover my day time power costs.
So, I tweaked a bit more. Underclocked the core about 100 mhz and bumped the memory up another 50 mhz, increased -w 256. Now I'm seeing an average of 600 KH/s with about 5% invalid rate. I'll take it.
