Novint Falcon anyone?
P074RB34R
Does anyone else in here have a Novint Falcon? I got mine yesterday and it was working fine, but every now and then after I close a game or change games, it will shut off:confused:, and I have to unplug it and start over again... other than that, i think it is the most awesome game controller I have ever used, it has quite a learning curve, but the tactile feedback from it is great!:)
Ive got one and I love it. I had a blast replaying HL2 with it. Its not as gimicky as it would seem to be, because it really can immerse you even more into the game. As for your problems, I'm not sure. Have you checked out the novint forums? They are really really helpful, the main guy TomNovint helps people out personally.
yep great gaming peripheral (love mine), but sounds like yours is not functioning 100% like it should. you may want to post in the novint forums and get some feedback (no pun intended) on that issue.
