1Wolf
- Jul 10, 2007
My machine is an Asus Z77 Mobo, i3770K, Corsair H100 with fans in push/pull for cooling. I built it nearly 3 years ago and its been running at stock speeds since then as I was able to play all games that I play with sliders maxxed, and do everything I needed, at stock just fine.
However, now I've picked up Witcher 3 and my i3770K seems to need a bit more horsepower so I figured I'd put a modest overclock on it. Nothing record breaking but just to squeeze a bit more out of it...thinking around 4.2 to 4.6...somewhere in there.
1) What are good, safe, 24x7, daily-use IDLE temps for the i3770K?
2) What are good, safe, under-load, gaming temps for the i3770K?
3) What are good, safe, 100% load, stress-test temps for the i3770K?
4) My ASUS board offers too "easy" overclock features under auto-tuning that I was really hoping to be able to take advantage of. The first is a simple "fast" overclock of just the CPU to around 4.2. The second performs several tests and reboots to overclock CPU and memory to attempt to get to a higher overclock while stable. I've overclocked a few machines "manually" before many years ago, but I still consider myself very much a "novice" at it. Its very time consuming and unfortunately I just don't have a ton of time so I was hoping that the "auto" features of my board might help me out or at least get me in the neighborhood and I could tweak from there. I'm sure you guys prefer completely manual overclocking, but for a novice, is the auto-overclock on the ASUS Z77 boards pretty decent? Can a novice generally trust the settings?
Thanks!
Thanks!
