frosty3907
- Mar 2, 2011
Hello all this is my first post on the forum but I'm a long time reader of the site.
I've done plenty of custom mods and computer jobs my whole life, I repair laptops and all kinds of stuff- when it comes to my PC I generally try and squeeze every little bit of performance out of it and to make that harder I usually use the cheapest bits I can find or recycle old gear.. generally it's not neat or pretty but it usually works
ANYWAY - my current job is upgrading my GTX 480 to a custom watercooling solution, it just runs too hot as I use it for fermi with progressive rendering.
However the proper water cooling solutions and blocks are far too expensive for my budget and so I'm looking at using a swiftech i-20 that I repaired (radiator leak):
In conjunction with the stock GTX heatsink:
which already has a big chunk of metal and proper component placement (obviously).
My current idea is this;
The GPU block has 5 heat transfer pipes running through it up into the cards radiator (see image above) which is cooled by the fan, from past experience I know these pipes are generally hollow and so it would seem these would be ideal to pump some water through, from the center looping back outwards as they go.
So do the experts foresee any problems? Likely with the connection between water line and heatpipe (no idea where to begin on that) and/or the different pipe diameters.. flow rate... etc...
Go easy if you think it's a stupid idea, I just hate spending hundreds of dollars on a lump of metal when I already have a large lump of metal available to use
