Nothing Appears on Screen
diggƒreak
So my friend dropped off a rig from around 2005 that he said died and he wasn't about to fix.
Specs:
Mobo: DFI NF4-DAGF (Nforce-4 Vanilla)
Ram: 512MB (Corsair XMS) 512 MB (Ultra [?], not inserted)
Case/PSU: RaidMax Cobra
Optical: [Some IDE combo drive]
HD: [Some IDE drive]
Floppy: [Some generic drive]
GPU: none, told me he sold it to a friend a while back, I have a spare 6600GT
Using my Logitech USB Mouse, IBM PS/2 Keyboard, and Dell DVI monitor.
After this thread working out the 20 to 24 pin power issue, flogge so nicely mailed me a 20-24 pin adapter. I plugged it in and pressed the power button. After some beeps (the kind that you might hear on a perfectly functional system), everything received power and I heard some hard drive activity. The problem was that nothing appeared on screen. A little too comfortable with this system already, I opened the case while it was on and put some pressure on my 6600GT. Nothing. So I turn it off, take out the card, and carefully reseat it. Reseat being a relative term, as his back panel has been more or less mutilated, and I had to bend away the metal dividers to get it to seat in the first place. The second time, it seemed as though all the pins were in the PCI-e slot, but still nothing on screen. I turned it off and tried pushing in the card a little more, and this is when I freaked out. Stupidly, I was putting pressure on the heatsink, and I felt the thermal contact break. In a hurry I got a pair of pliers and took off the heatsink, I hadn't crushed the die. When I get home I'm going to reseat the heatsink with some arctic silver, I really hope I havent ruined my faithful 66GT.
In any case, or I should say, In any other case, I think this hardware would work. My current plan is to run the mobo next to the case like a testbed, to see if I can push the video card in all the way. I also need to acquire a PCI video card to see if the slot is dead. I also have the feeling that I should look up beep codes for this mobo, but they really do sound pretty normal.
What does [H] think about this situation?
do you get error beeps without the vidcard?
do you get error beeps without the ram?
if yes to both, then find known working parts for each and re-test.
Well, sorry for bumping an old thread, but I finally got this machine running last night.
Was getting the 1 long 2 short beeps from an Award BIOS indicating a video problem. I had to start it up with an old Trident 2MB PCI card and some fresh RAM, change some BIOS settings, and then slapped in a 6600GT.
Whatever Windows was blue-screening on boot, so I reformatted with XP pro.
Specs of the machine right now:
Althlon 64 3000+ @ 1.8 Ghz
512MB of PC3200 from my friend's old Dell
Gigabyte 6600GT 128MB
DFI nF4-DAGF
40GB Quantum Fireball HD
Sony DVD-ROM
Raidmax Cobra Case
Raidmax 400W PSU
Cost to me: putting my old 6600GT to use.
Plays Call of Duty:UO wonderfully! ;)
