notfreds question
That is a choice you have to make.
If you want to run two SMP clients on your quad .. then yes ..
There are two camps on this issue.
1) PPD Camp - Run two SMP (As long as they meet deadlines) and get more points
2) Work Camp - The Faster the work unit gets done, the better it is for the science.
I know in Windows, we have Affinity changer.
In a GUI Linux, I know you can use taskset.
I am not sure how this is being handled in the Folding CD, but it should work just fine.
I have not seen any body complaining about it, but I don't know for sure.
My two headless Q6^00's run that way. And they get the work done in time. But I have a 3.2Ghz clock on them. I think anything lower than a 2.8Ghz and you will hit some WU's that do not get done in time running 2x clients.
Thanks. Well, since the disc is strictly for the chimp challenge, I'll aim for the ppd.
I am going to be out of town the beginning of next week, and I want to make sure there are no problems
Mucho good luck delvryboy and thanks for the effort ;)
OBTW I'm sorry I can't help you, but I don't know "jack" about notfreds folding disks. I have read good reviews on them though :confused:
