DOHCVTECLUDE
- Jun 9, 2004
I was recently given a pretty nice notebook by a good friend of mine. He got a new one because he felt this one was rather sluggish, dispite the fact that it's fairly brand new. It is a HP Pavillion ze4115 with an AMD Athlon XP 1500+ (which is supposed to run at 1333Mhz). Well, I re-installed a fresh copy of XP Pro on it, and began playing with it a little bit. I also noticed a bit of sluggish-ness from it, for example my computer taking 15-20 seconds to open on the screen, and things just kind of hanging. Well, I downloaded the utility "wcpuid" which allows you to check the cpu speed in real time, and to my surprise when I ran it, it said I was only at 662Mhz. This would explain the notebook being sluggish. I went into the BIOS to check for any settings I might change to correct this, and I found nothing of the sort. Can anybody help me fix this problem and get this thing running at full speed again?
