I have had the strange errors at post where different error codes are given each time and the bios seems corrupt. A new bios flash did nothing so I was getting frustrated. I could not get the system to post and was getting the same beep you get from a bad overclocking try but after 20 attempts to boot and letting the system sit and beep for several minutes I had no responce and the monitor was not getting signal. So I removed the atx connectors the memory and the cmos battery. I moved the cmos clear jumper to clear the cmos waited about 30 seconds and tried it repeatedly. Then connected everything but left the cmos battery out. So far I have run for 10 hours straight then reset several times and am going to continue testing with no cmos battery. If anyone figures out what is wrong with the VNF3-250 bios I sure would like to know.
