Not sure where to put this
Eze1
Sup everyone. Well let me discuss the issue a littlebit.
This problem is basicly is in all my games I have very poor perfomance. The only game that I can play that this issue doesn't really affect is call of duty (1 and united offensive) why it doesn't affect me much I really don't know I still get low fps and all that.
My ram is fine, cpu is fine. everything seems to be fine. I have no viruses or spyware and everything is up to date
Specs
3.2ghz
1GB of ram
ati all in wonder x800xl 256mb
160gig HD (2 80 GIG)
800 bus.
Tempatures
Temp 1 is usually 30 degrees C
Temp 2 is usually 46 degree C
Temp 3 goes from -47C to 111C to 50C (not in that order but its not within the same limits)
anyone got a suggustion?
Please keep in mind cod:uo does run on a playable scale even with this fps which would explain why I've played so much of it
http://img117.imageshack.us/my.php?...untitled5mp.jpg
Condition Zero
http://img117.imageshack.us/my.php?...ntitled12fs.jpg
KEEP IN MIND MY GFX ARE NOT MAXED OUT ON COD:UO ITS ON NORMAL AND CZ ON 16-BIT DETAIL
PS I don't know why my cod:uo screenies come out dark
I am 100% sure I've already done that. Those are the ones that come with the motherboard disc. If not please provide me a link for intel pent 4 chipset drivers.
I have a gigabyte motherboard. See I was thinking that the motherboard might be the problem because everything else is changed or new. So if you know of a program or something. Back back to the topic, yea Gigabyte
this is on topic
what model motherboard do you have?
Or what chipset?
go to nvidia.com and make sure that you download "nf4 amd chipset drivers". i think the most recent is 6.70. make sure your catalyst drivers are up to date. run a program like 3dmark01 or 3dmark05 to get an idea of how your vid card is performing (relatively). also download sisift sandra and run the memory benchmark. by these scores we can tell if your rig is running up to par.report back.
sorry. i assumed you had an amd nf4 until i saw your cpu speed. disregard my first 2 sentences. regard my other ones.
you're having low fps in CZ?!? Is that possible?
ok...what computer do you have...did you build it or is it a dell/gateway/etc?
we need more info about your computer
The exact model of your mobo would help. Try this though.....
Defrag your HDDs. If it is an Intel based mobo you are using, get the latest chipset drivers here:
Intel INF update
If it is an nVidia based mobo, download the latest chipset drivers here:
Intel nonSLI version Forceware
Intel SLI Version Forceware
You have an ATI based card. Are you using the latest drivers? If not. try here:
ATI Catalyst 6.2
Check to see if you have any spyware. Check to see if you have any viruses. You're running RAID 0 I assume? Why? It doesn't help you in games and really is very risky if you don't back it up frequently.
This is on my motherboard Box and Booklet
RZ Series Motherboard
8S661FXM-RZ
SiS 661FX chipset
and my pc is a Cusom PC. I had it built about 2 years ago but I've upgraded it several times basicly everything but my motherboard
Make sure you've got the stuff installed that was in your motherboard disk. You might want to make sure you have the AGP GART driver (go to the SiS website and download it).
Yeah everything on the disk is installed and right now I am going to the SiS site and getting the AGP GART item
Ok,
Ignore what I said about the mobo drivers then since it is a SIS mobo. But do go to the SiS website and get the latest mobo drivers for your mobo.
I would still update the drivers for your video card though.
I have ati 6.2 drivers and I've had them since the day they came out. I just installed those GART drivers I am also downloading the SiS UniVGA3 Graphics Driver. Do I need that?
No, you do not need the SiS graphics drivers.
mmm........ weird thing. I join a cz server and my fps is 100, then it drops to 60 then 40 then stays at about 20
that sounds like throttling but i dont think your cpu would be throttled if you were playing a game. post some sandra scores or 3dmark01 and 05. need to know how your pc is performing relative to how it SHOULD be performing.
With Sandra what exactly would you like me to scan or beanchmark?
