not sure what is the problem (booting)
Billiam411
ok first here are the specs:
AMD athlon 64 2800+ (s754)
ASUS K8N (plain)
ATI all in wonder 9800 pro (agp)
1.5gb Crucial DDR
120gb Western Digital boot drive
windows xp sp2
i went to restart my computer, and just after POSTing, it would immidiately restart, without even reaching the windows loading screen. i restart and boot into safe mode, same problem. 'last known good configuration' does just the same. it was initally looking to be a fan problem, because the cpu fan would turn off a few seconds before the system would restart, but that doesnt seem to be the case anymore. temps according to the BIOS seem pretty fine, 38 for the cpu and 29 for the case. i swapped the ati card out for an old asus nvidia based card, and it would still not boot (the card has given me problems in the past), this time though, it would do some pretty sparatic stuff. one time i restarted and it gave me a blank blue screen. another time it would go to the windows loading screen and then reboot again. one time it did give me a BSOD (with text on it):
i am now here typing this on another laptop, and i will keep trying and will update with any changes.
anyone have any ideas as to what could be causing this? i could always wipe the drive but i dont want to do that yet, only as a last resort. ill try removing some of the memory modules right now
Sounds like your system is double / triple faulting due to the corrupted RAM.
If you have added RAM recently, take it out and try again. If thats not the case try one stick instead of two, alternate them, if thats not the problem it may be your processors L2 cache.
But thats just one mans opinion, and it's mine but mine usually doesn't mean much.
ok, i took out all but one stick of ram. it began to load windows, but then flashed a BSOD for a fraction of a second, then restarted but there was no post video signal, just a blank screen (there was a signal though, supposedly). this is when i noticed the cpu fan had stopped.
hmmm
ok its basically immediately after the post beep that the fan stops.
i plugged in another case fan into the cpu fan header (while holding a spare fan over the cpu heatsink) and it gave me a 'cpu fan error' during post, and the case fan stopped.
no bios updates for this mobo as it is quite old. i just tried clearing the cmos but that did nothing, also tried swapping out the memory for a different stick but also nothing.
basically what is happening is that immediately after the post, the cpu fan turns off, and while loading windows, a BSOD flashes on the screen, then it goes blank and restarts.
Get into the BIOS and shut off all the fan controls so that everything runs 100% ON all of the time. The BSOD is probably related to an overheating CPU.
i just tried to turn of qfan, but by the time i got into the bios the fan was already stopped (scaring the crap out of me, because its not automatically restarting to turn the fan back on) and within a few seconds it froze.
hmmm
You say you took out all but 1 stick, did you try removing that 1 and replacing it with a different one?
face a room fan at the side of your case to keep it cool while you disable QFan. Then, run memtest on each stick of ram, one at a time, for at least 4 hours, to get a few passes done.
i did switch out the memory for a different stick, but i'll run memtest now, be back in 3x4=12 hours :eek::D
hm, the cpu fan is staying on now, but it still wont boot properly.
should i run memtest with the ati card or a different one that i have that i know works?
ah! memtest failed!
literally minutes before i was about to switch to a different stick and restart the test.
i have 4 sticks of memory, i use 3 of them. they are all the same model of crucial memory, 2 of them are 2nd revisions or something 'ct6464z40b.16t' vs 'ct6464z40b.16tg2'
so now i know the old stick of memory that i use (g1) is bad, ill remove it and try just one of the new sticks / both of them and see where that gets me.
edit:
ok the second stick (new version) failed also
looking here:
http://hcidesign.com/memtest/manual.html
does this mean that my motherboard is at fault now?
