Not stable at common overclock!
ImFallingAsleep
2.6C@3.25GHz/250MHz FSB
OCZ PC4000 2x512MB @ 2.5-4-4-7 (By SPD)
Abit IC7-MAX3
Divider at 1:1
vCore at 1.575 and fluctuating between 1.50-1.55v
vDIMM at 2.9v
AGP/PCI locked at 66/33
Fortron/Source 400W PSU
Latest BIOS update
I assume it's not heat that's doing this. I'm using a mirror-finish lapped Swiftech MCX4000-B, Artic Silver 3, and a Thermaltake Smart Fan II at ~75CFM/4800RPM blowing down, three ~34CFM fans blowing in, and two ~28CFM fans blowing out, not including the PSU fan. It runs at ~40-43 idle, and I've seen it up to 50 degrees before it's crashed.
Well here's the deal. It boots at the overclock mentioned above, boot times seem sluggish, more so then at lower FSBs I've tried. Anyway, I'm getting ILLEGAL SUMOUT in Prime95. It's supposedly a hardware error. I've been having quite a few lock ups and sudden restarts. The CMOS has been reset three times now.
How come people are doing 2.6C@3.25 w/ 250MHz FSB with STOCK COOLING AND STOCK VOLTAGES? Most say they STILL have headroom for a larger OC and yet it took all afternoon to get it stable at 250MHz FSB with a 1:1 divider, and it crashes when it does anything remotely taxing like loading a game or using Prime95. Hell it's restarted suddenly doing NOTHING from the desktop.
What's goin' on? Do you think it's the motherboard, CPU, or memory? Aren't these voltages high enough?
Apparently the MAX3 doesn't regulate voltage well over 2.8v to the DIMMs, but I set mine to 2.9v and then 3.0v and both times MBM has told me they're exactly 2.91v and 3.02v. I also set my vCore to 1.65v and reads 1.60~1.65v, yet Prime95 still crashes within minutes of enduring a torture test.
you have exceeded the max OC of your chip man. Unless you feel comfortable pumping 1.8v or so thru that P4 Id say back off till it is stable, or try and back off on your memory timings and see if that helps. But end of story you may end up having to back off the OC. Remember just because others get those speeds doesnt mean you will.
I get stuck with that type of things around 650mhz OC myself. 550mhz is my sweet spot. So bump it down to 3.15 and see what it does.
if your rig is brand new try something
boot 245mhz fsb and run a cpu cruncher for a few days straight and "Burn" the proc in
Many people say thats not true but it worked for me
WHen i got my sys, I couldnt get much higher than 250-260 fsb
Now i can boot 280 5:4
luck
for a new chip. If youve had the sys for 3 months your 2.6c aint a g00d ocer
luck
if memory serves me right, your ram is sitting at
280/5 x 4 = 224mhz
so if my math is right then your actually running slower than your 245mhz
LOL Visable-assassin, that's funny. Yeah, it's nice and stable at 245MHz FSB with 1.575 vCore (actual around 1.53~1.57v). I'll try laxin' the timings just to see if it'll help, but thank you to all that replied.
im not talking mem bandwidth
Im talking about actual CPU o/c
No i dont boot at 280 b/c i lose performance
right now with 2.8v's in the ram i can boot 1:1 2.5-3-3-7 at 263
When I get my case up from moddin Ill try bootin 3v's into em and maybe 270 since i know my cpu will do 280 as shown above
and no i didnt get pwned
Originally posted by kleptophobiac
Overclocking is a gamble
dont ever think that just cuz others are getting those results, that you will to
ImFallingAsleep glad I could make ya laugh bud :)
But on your P4 watch your vcore man...I think P4's seem to die at around 1.7 or 1.8v I forget....as for your ram trying to relax your timings a bit then post back to us :)
if you are useing 280 with the 5:4 divisor yes you are losing performance...now if your speaking from a 1:1 divisor youd have it made. And as for pumping 3v into ram...myself I would never recomend it...
Hes talking about the actual CPU working at 280 FSB after burn in regardless of ram divider... obviously 5:4 is slower then 1:1.
as long as you have decent cooling, bump the voltage a notch. you could also try lowering the memory divider.
as for the burn-in, see my sig.
Originally posted by DiseasedCow
I have the max2, and the latest bios...
so they may have changed the voltage of the max3
I'm talking about revisions of the same motherboard. There were NF7-S 1.0, 1.1, 1.2 and 2.0.
The MAX3 goes up to 3.2v vdimm.
TO: Original thread poster... stepping? Don't even bother posting an oc failure without the stepping.
:rolleyes:
a little offtopic, but when do you actaully have to change the voltage? miens at .25+, all i do is change the fsb, not messng with the voltage. im using an msi kt3 ultra. thanks.
you can overclock quite a ways on stock voltage, depending on the chip, but upping the voltage a bit opens up a lot more headroom.
Unfortunately my TH7-II RAID runs at 1.6V max:rolleyes:
I'd do a volt mod, but my temps are kind of high already.
