somecallmeTim
- May 28, 2001
Okay, this has me stumped...
I have a Celestia A2210 dual s940 1U server. The motherboard is an AMD Serenade, rev 3.02 is the best I could do for a model. The manual is very light on this system - tells more how to take it apart than put it together.
I got the server as a barebones, just needed CPUs, RAM, and HD. My CPUs arrived last night, a pair of Opteron 250s (800 Mhz HT), installed them both and it fires up and then hangs with no video signal and only the H0 LED is lit. Power LEDs on the motherboard are okay, and so are all the other indicators, except the "fault" light on the front panel.
I swapped HDs (two Fujitsu 73 GB 10K SCSI320), same thing, pulled ram, swapped ram, same thing.
Got tired of it last night and dinked with it this morning. I pulled the CPU from the H1 socket and it fired right up. I tested all the ram - currently have four 512 sticks of PC2100 ECC, and both drives test out fine. I also swapped CPUs and both test out fine in H0.
There are two set of switches on the motherboard - SW3 and SW4. According to the diagram, I have them set correctly.
The server is at home, I'm at work (sorry) - so the question is, anyone know of anything obvious that I am missing? OR what to look for?
![](http://www.hardfolding.com/ftag1.php/mem/565.png)
