trugbilddrachen
- Jan 28, 2002
Not receiving any email notifications... not sure if its just me...
Thanks
John
Thanks
John
Do you guys even get that many PMs? Is it so hard to look in the upper right corner from time to time?
Or would you only load the forum if someone PMs you?
But if I am at work and in the middle of a deal here, I can not always log on to check for PM,s.
Oldie,
You have received a new private message at [H]ard|Forum from (user name of the sender). Please click here to log in and read it:
http://www.hardforum.com/private.php
Thanks,
[H]ard|Forum team
Then you can't load the forum and view the PM anyway.![]()
I've had these enabled and working in the past, and the text of the notification only informs you that a PM has been received, and does not contain the content of the message. It is still necessary to log on to the forum to view the message. If you're trying to have the message forwarded to you, I don't believe that's possible. I would simply post the hours you're available to correspond in your thread to avoid anyone feeling that you're being unresponsive.
Here's an example of the message that's sent when notification is working and enabled:
