I'm trying to create a batch that moves .tif images from one directory to another, after those have copied it will then copy a .dat file to the same directory. Then move on to the next directory. I'm a little confused on how I go about this because all I've done is very basic, simple batches and I'm not sure how to begin with this task.
Below is an example of my directory structure.
I'm wanting the batch to go into the XXXX directory in the ProcessedBatches directory, copy every .tif file within that directory, move it to a destination directory, then copy the .dat file in the XXXX directory, move that into the destination directory, and then move on to the next directory within the root of ProcessedBatches directory and repeat the same process.
This may seem like an overwhelming amount of information, maybe it is. I'm not asking you to write the actual code for me (if you did i'd love you forever though.) .... I'm just looking for someone who may be able to point me in the right direction on where to begin (yes, I've browsed through example batch files and searched the forum)
Thanks for any help you give me!
--drpunkerz
--drpunkerz
