NOT just another "should i build now or wait for conroe thread"
Discussion in 'Intel Processors' started by nytrackstar, Apr 16, 2006.
  1. nytrackstar
    nytrackstar Gawd
    651
    Aug 3, 2004
    I'm looking to build a brand new system sometime around may, I've started planning out different possible components that i'd be getting. (This system MUST be done before august)
    One of the most critical parts to this system is the storage subsystem, i will need a strictly hardware based sata-II controller card for my RAID-5,RAID-0 arrays...
    the plan as of now is to grap a pressler 950 after the price drops for around ~300 and OC the life out of it (everything will be watercooled)
    I need a motherboard that will be able to support the following:
    -pci-x or extra pci-e slot for raid card
    -2 x16 slots (doesnt matter if its true x16 or not, x8 is fine too) for SLi or CF
    -overclocking options (this eliminates most workstation boards)
    -support for 4Gigs of ram or more
    the only motherboard that comes to mind is the Asus P5WDG2-WS board, but with conroe support unknown i'm not sure if i'll regret this purchase down the line, im also unsure if there will be any conroe boards that will support the featureset that i need...
    ...this machine is going to be my do it all machine, gaming, mediacenter, storage for files...and ive eliminated goin with AMD just because ive had both amd and intel rigs and intel ones have always "just worked", aside from the fact that no motherboard for AMD supports the things i need.
    in addition, i'll be placing an x-fi, and hauppauge dual tv tuner in this box, over 2.5 terabytes of storage and either CF x1900xtx's or sli'd 7900gtx's (if theres an nvidia intel mobo i dont know of out there)
    opinions?
  2. EQTakeOffense
    EQTakeOffense [H]ard|Gawd
    1,643
    Sep 12, 2002
  3. nytrackstar
    nytrackstar Gawd
    651
    Aug 3, 2004
    i wont be able to use that board, not sure if the spacing between the pci-e x16 and pci cards is enough and to my knowledge there arent any quality raid cards that work in a standard pci slot...i could be wrong tho...i definately appreciate the effort tho :)
    any other opinions?
  4. vapb400
    vapb400 Gawd
    786
    Sep 19, 2004
    I wouldn't suggest any Intel SLI chipset for a computer requiring robust storage and where you intend to overclock. I think the P5WDG2-WS is your best bet
    but the Gigabyte GA-G1975X does have a decent layout for what you need:
    http://www.newegg.com/Product/Product.asp?Item=N82E16813128002
    the intel seems to have right layout as well:
    http://www.newegg.com/Product/Product.asp?Item=N82E16813121016
    dunno if you'd be able to get the oc you want, but it'd be a pretty nice one.
    PCI-E raid cards are very very expensive, i'm thinking the WS + PCI-X raid would be your best choice.
  5. EQTakeOffense
    1,643
    Sep 12, 2002
    Raid Card - 7900GTX - 7900GTX - Hauppauge - X-Fi
    PCI-X - PCI-X16 - PCI-X16 - PCI - PCI
    How do you not have enough room?
  6. RavenD
    RavenD [H]ard|Gawd
    1,516
    Jun 30, 2005
    Just be sure to get a rock solid PSU for that rig. I personally wouldnt get anything short of PC P&C for a setup like that.
  7. chrisf6969
    chrisf6969 [H]ardForum Junkie
    9,014
    Oct 27, 2003
    this is just another "should I build or wait" threads. :mad:
    I don't see anything special about it!
    Wait A LITTLE LONGER to be sure your motherboard supports Conroe. The 975 boards being made now will support Conroe. Unfortunately most of the ones on sale right now, were made a few months ago, so you'll have to wait a little while for inventory to clear. Then you should get something like the Asus workstation board, it has PCI-X, overclocks well, in general should have everything you need.
    And just buy a 920 or 930 to save some money, so in fall you could upgrade to a Conroe with just a drop in chip replacement.
  8. osalcido
    osalcido [H]ard|Gawd
    1,481
    Nov 10, 2005
    I agree!
    Got suckered in by the title :mad:
  9. nytrackstar
    nytrackstar Gawd
    651
    Aug 3, 2004
    appreciate all the help guys!
