Not getting any bonus points.
steelman2202
What did I do wrong? Folding 6.34 command line client on windows 7 64bit. Have folded more than 10 SMP WU's (I think, only know 8 wu's to be definitely not SMP). I've set the config to get big WU's, disable affinity lock and set "-smp" as a parameter. Also included my passkey. It says passkey found if I remember correctly.
Not getting any bonus points at all. Just finished 10134 and crunching on another one now. These two should be the 12th and 13th SMP WU's I've done.
Any ideas?
Thanks.
What is your user name for folding? What are your machine specs?
2700K, 8gigs of ram. User name above is correct. Machine folds pretty much 24/7. Multiple clients only because I've nuked this machine a few times in trying to get it to behave. I've also ran a bit on linux but was unable to upload WU's... (2 WU's to be precise)
"nuked this machine a few times" How many, That may be the reason you may not be at 80% completed
I've nuked it twice - once running windows 7, and once running Ubuntu. Does the 80% WU's work for SMP only? (I'm sure I'm over 80% for all WU's) There may be 3 or 4 incomplete SMP WU's. Is that the problem?
Yes SMP only, Have to have 80% complete uploaded , partials count against you too
With one of my machines I kept on losing a disk and had to reinstall the OS. This was like 4 days in a row where it would download a WU get part way through and crash. It took 10 WU until I started to get more favorable WUs.
