Not enough space.
berrmich
Here is my setup:
Supermicro x8si6-f-o
Xenon 3440
8gb Kingston ECC
Norco 4020
Corsair 850AX
5 x 2tb Samsung F4s
128gb kingston SSD
ESXi with open indiana (raidz 5x2gb) and WHS.
When I try to move larger amounts of data to the zfs folder from my windows 7 machine, I get a "not enough space" error. If I move it over in smaller quantities it does fine. For example I was moving over 2 movies at about 10 gb a piece. I could do each of them separately but not together. Other times I can move over 5 movies at a time without getting the error. Any idea's?
-Mike
My friend who has the same set up has the exact same problem. Anyone have any ideas?
-Mike
don't know what that means...but it happened right way after I set everything up....
-Mike
Here you go:
Unlike of the fsck command which had to be run on an unmounted filesystem (read: downtime), the zpool command has a scrub option which works on a mounted, living filesystem. When run, the command checks all data in the pool for checksum consistency. On redundant systems (raidz or mirror), inconsistencies will be repaired.
To scrub the pool techrx:
zpool scrub techrx
The command creates lots of IO, so use judiciously. Only one scrub session is permitted at a time. To stop scrubbing a pool, use the -s option:
zpool scrub -s techrx
