I don't have enough space to plug the cable from the front panel of the case to the 19-pin USB 3 Header on the motherboard. The cable has to be bent very sharply because the hard disk cage is in the way. I am concerned about this because it puts a lot of force on the cable and the motherboard, I am concerned that these could be damaged.
I have put a photograph here to show the problem:
http://www.euclideanspace.com/tech/pc/pc2012/build/installMB/index.htm#usb3hdr
This page also has details of my build.
Is it possible to get a 90 degree adaptor for 19-pin USB 3 Headers? Or is there some other way round the problem (without doing any mods)?
Martin
Martin
