*SIGH*
I just purchased an ASUS 8800GTX card and I wasn't surprised when my current PSU didn't provide enough power for that card, I kinda expected that.
Then I went and purchased a new PSU that I think should be able to work, but it doesn't I still get the not enough power indicator
I was looking through the options and decided on the Thermaltake Toughpower 750W
http://www.thermaltake.com/product/Power/ToughPower/W0117/w0117.asp
It simply should work I don't get why it doesn't
The rest of my system
Core2 Duo 6600
4x512 DDR2
1x10,000 rpm sata
1x7,200 rpm sata
1xDVD R/W sata
1 SB XFI
Nothing is OC'ed, case and MB is a DELL XPS401 I think it's called in the US, it's called Dimension 9200 where I live.
I'll try to remove some components and see if it helps, but post any suggestions that you have to make this POS work (sorry but this is ticking me off).
EDIT: don't mind my sig it's ancient.
Core2 Duo 6600
4x512 DDR2
1x10,000 rpm sata
1x7,200 rpm sata
1xDVD R/W sata
1 SB XFI
