Northbridge Waterblock - What are you using?
Deadlierchair
I'm interested in a chipset waterblock BUT so many people everywhere say that they lower your flow like nobody's business.
In a high flow system what would all of you use?
D-Tek Chipset Block
DangerDen Z-Chip
These are the two I've been thinking about the most.
What are all of you using? I don't want some crappy Koolance block either. Also, don't try and tell me northbridge cooling isn't necessary, mine gets unstable really fast without air over it and I want to get rid of more fans. This is for a the below system, but if anyone wants to share what they're using that'd be great.
Out of those 2, the Dtek probely flows better just by looking at it...I have used the Zchipset, its liek haveing 2 right angels in your loop. But it worked prett good. I dont think it matters, no matter witch way you go ater on a NB is extreme..so they will all work well..
Did you look at swiftchs chipset block...looks to have better flows.. http://www.swiftnets.com/products/mcw20.asp
I'm using the Z-Chipset block. It's been on 2 hours. It does slow the flow down a little, but if you have a good pump no worries. I'm gonna do the chipset vmod later tonight, and see if I can get more than 233FSB out of my NF7-S.
