Sep 3, 2006 #1 C ctantra Weaksauce Joined Aug 29, 2006 Messages 91 The Northbridge on my DS3 is running very very hot. Do you think this problem bios-update fixable? (DS3 on F4 bios now). I know I can add some extra fans, but I'm using the PC as HTPC, so I want it as silence as possible. Thanks. Regards, LimLim
Sep 5, 2006 #2 V VulturEMaN Gawd Joined Sep 11, 2005 Messages 1,017 If it's not a bios problem, then I'd grab one of these (if it can fit). http://www.newegg.com/Product/Product.asp?Item=N82E16835109128 I'm sure you could prolly get away without a fan, but I've found that the 40mm fans are completely silent. If you're deadset on having it silent, then I'd wait till these are back in stock: http://www.newegg.com/Product/Product.asp?Item=N82E16835108072 ^as cool as you'll ever get the nb without watercooling
Sep 5, 2006 #3 W WickedWeasel Limp Gawd Joined Jul 13, 2004 Messages 444 Reseating the heatsink with AS5 might help?
