northbridge overheating
Originally Posted by dekruyter
Only one voltage monitored, as far as I know. Temps, mine doesn't.
Maybe your M/B is not detected fully by the program.
I see 6 out of 8 voltages, 2 system temps, 2 sys fans, core temps along with GPU and HD temps.
Here is a text read out (sorry the screen capture did not look good enough to post).
Hardware Monitors
Hardware monitor ITE IT87
Voltage 0 1.10 Volts [0x45] (CPU VCORE)
Voltage 1 1.98 Volts [0x7C] (DDR)
Voltage 2 3.33 Volts [0xD0] (+3.3V)
Voltage 3 4.92 Volts [0xB7] (+5V)
Voltage 7 11.97 Volts [0xBB] (+12V)
Voltage 8 3.25 Volts [0xCB] (VBAT)
Temperature 0 46°C (114°F) [0x2E] (System)
Temperature 1 29°C (84°F) [0x1D] (CPU)
Fan 0 1138 RPM [0x251] (FANIN0)
Fan 3 1038 RPM [0x28A] (FANIN3)
Hardware monitor Intel Core 2 Duo E8400
Temperature 0 37°C (98°F) [0x3F] (Core #0)
Temperature 1 37°C (98°F) [0x3F] (Core #1)
Hardware monitor NVIDIA GeForce 9800 GTX+
Temperature 0 62°C (143°F) (GPU Core)
Hardware monitor WDC WD2500AAKS-22B3A0
Temperature 0 32°C (89°F) [0x20] (Assembly)
Someone correct me im wrong but i havent seen any i7 run at or over 4ghz stable with less than 1.35 vcore
The last one I had did - 1.296V, 19x211=4009. I think the hardware monitor on the motherboard lied though, based on the temperatures it was running. The same chip in a different board needed over 1.35V and didn't quite hit 4GHz.
well calling it stable is debatable, but it's stable enough to fold. take a look:
edit: here is a more readable pic
temps look fine id probably up the voltage just a tad.. probably will make it a little more stable..
yeah it's crashed a couple times today. each time i upped the voltage just a tad. it has been stable most of the day though
Yes, it's possible. Both of my 920's run at 4 Ghz and the VCore is only 1.275 on them.
