Hi all,
I have a aopen motherboard that one of the wire loops that the northbridge heatsink clips into, has broken off. are there any solutions to fix this? any help would be much appreciated.
Did the whole thing come off? If so, two holes should appear and you should be able to use strong string to hold the HS clip. Or better yet, if you have soldering experience, you can just stick that thing back in and solder it from the back of the mobo.
