Northbridge fan direction?
IceWeasel
I'm modifying my northbridge with some active cooling in the form of a 40mm fan. Do I want to mount it blowing onto the chip or sucking air off of the chip? (There is a heatsink between the 2)
Also, I mounted a heatsink on my southbridge as well, should I mount a fan there as well? I have plenty of fans laying around to use. :D
Thanks!
blowing down... a heat sink is sufficient on the SB, no need for a fan -- but if you have it laying around you can go crazy, I guess -- that's what makes this hobby interesting :p
