So up to now I've only had 1 120mm fan in the front of my case to pull air through and I haven't cleaned it for a while (year+). So I got 2 new 120mm fans and installed those and cleaned out my comp.
Temps dropped by 10 across all cores! Went from 48-51 idle to 38-41.
The reason why I asked if this is normal is because the fan I had plugged in before to the front of the case was into the motherboard, but these other fans I have hooked through the power supply. Would the mobo have been detecting the temps based off that old fan? Or is this really how much a proper fan setup and cleanup job can help?
